Valvole finali per slo
nashtir
Messaggio da nashtir » 07/12/2008, 13:32
Ciao ragazzi, mi chiedevo che opzioni per le finali di una slo si potessero avere, pensando comunque di restare su 6l6, ho letto che soldano usa delle sovtek 5881/6l6 ma ci sono due modelli diversi, altri consigliano le tad big bottle che son più presenti sugli estremi (lo e hi) o le tad short bottle che son più rotonde e morbide, altri sconsigliano le jj perchè suonerebbero un po' impastate..voi che dite?
SandMan84
Re:Valvole finali per slo
Messaggio da SandMan84 » 07/12/2008, 13:50
Trovato nel Web  :lol1:
The very first SLO 100s used Philips 6L6GC power tubes
and GE 12AX7 preamp tubes. We switched to Chinese 12AX7s almost immediately when they
became available. They sounded good and were usually not very microphonic. However the
Chinese tubes became unavailable several years ago, so we looked around at the various 12AX7s
that were available, and decided that the Sovtek 12AX7LP and 12AX7LPS tubes sounded the best.
We've been using them ever since. The Chinese tubes are now available again, but I think the
Sovteks do sound better. The 12AX7LP and LPS sound the same, with the LPS being slightly less
noisy. The only thing I must warn you about is that the 12AX7LPS can not handle very high
cathode voltages, such as that which exists in the phase inverter, and tone and effects loop drivers,
of the SLO - so you must use the 12AX7LP in those positions. I recommend that you use a
12AX7LPS only in the "first" position (the tube closest to the input jack) and the 12AX7LP in the
others. That's what the tube line up is in all new SLO 100s, and it sounds great!
My favorite power tubes, which we have been using for many years, are the Sovtek 5881s - I like
them a lot. They sound good and they're very rugged and reliable. They are also probably the most
consistent, in terms of performance and quality, of any tube I've used. We also offer the new
Groove Tubes KT66 as an option for players wanting more "aggressive" attack from their amp.
They've proven to be very good tubes as well. If you chose to run the KT66s, you would definitely
have to rebias the amp, as they require a higher bias voltage."
Mike
:rockon:
Messaggio da robi » 07/12/2008, 17:41
Con le C logo non sbagli mai.  :king:
nashtir
Messaggio da nashtir » 07/12/2008, 19:40
robi ha scritto: Con le C logo non sbagli mai.  :king:
C logo? intendi le winged c?
meritil
Messaggio da meritil » 07/12/2008, 20:25
io ho letto che qualcuno ha messo le EL34 sulla slo ed è rimasto molto soddisfatto...
cmqe voto anche io winged C (e pure kt66 invece che 5881)
Messaggio da robi » 07/12/2008, 20:51
Sulla mia simil-slo con finale plexi le el34 sono una goduria. Poi adoro il feel delle el34 nella band. Non le ho consigliate solo perchè si chiedeva di 6L6, ma confermo quanto detto da meritil (e da Nutshell nel suo tutorial, se ricordo bene): le el34 son grandi sulla SLO!
nashtir
Messaggio da nashtir » 07/12/2008, 21:25
Ma posso sostituirle solo rifacendo il bias? Sapete, son indeciso tra le tad e le winged c, però se tutti mi consigliate quelle:)
meritil
Messaggio da meritil » 08/12/2008, 5:42
nashtir ha scritto: Ma posso sostituirle solo rifacendo il bias? Sapete, son indeciso tra le tad e le winged c, però se tutti mi consigliate quelle:)
TAD ha le winged C premium matchate guarda bene  :ciao:
El.guerrero
Messaggio da El.guerrero » 08/12/2008, 12:25
Io proprio ieri ho smontato le mie kt77 (che mi piacciono molto)
E cosi' al volo con una regolatina di bias ho montato le Kt88 e sono rimasto davvero soddisfatto.
Sono entrambe ottime ma con tonalita' molto diverse.
Inoltre la kt88 ha molto + headroom.
Comunque sia consiglio el34 per avere un miglior clean
