Domenico hai questi ?
https://www.mouser.com/datasheet/2/676/ ... 649057.pdf
.MODEL J2N4416A NJF
+ Beta=989.4u
+ Betatce=-.5
+ Rd=1 Rs=1
+ Lambda=5.5m
+ Vto=-3.06
+ Vtotc=-2.5m
+ Is=33.57f
+ Isr=322.4f
+ Alpha=311.7
+ Vk=243.6
+ Cgd=1.6p
+ Cgs=2.414p
+ Kf=7.445E-18
+ Af=1
https://www.interfet.com/jfet-datasheet ... terfet.pdf
NATIONAL SEMICONDUCTOR / 2N4416A
JFET N-CHANNEL – TO-72
DATI ELETTRICI
1. IDSS (VDS = 10 V, VGS = 0 V)
Min: 5 mA
Max: 15 mA
Tipico: circa 10 mA
2. gfs (forward transconductance)
Min: 4,5 mS
Max: 7,5 mS
3. VGS(off)
Min: −2,5 V
Max: −6 V
4. rDS(on)
Max: 150 Ω
(specificato a ID = 1 mA, VGS = 0 V)
5. Ciss
Max: 4 pF
6. Crss
Max: 0,8 pF
7. Noise Figure (NF)
Max: 4 dB
f = 400 MHz
RG = 1 kΩ
Valore tipico riportato da Vishay/Siliconix:
circa 3 dB @ 400 MHz
8. Common-Source Power Gain (Gps)
f = 400 MHz
VDS = 15 V
ID = 5 mA
Min: 10 dB
Valore tipico riportato:
circa 13 dB @ 400 MHz
DATI AGGIUNTIVI IMPORTANTI
9. VDS / V(BR)DSS
35 V
10. V(BR)GSS
35 V
11. Gate leakage current
Max: 100 pA
12. Package
TO-72
JEDEC: TO-206AF / Case 251
NOTA
Il 2N4416A appartiene alla famiglia dei JFET
N-channel ad alta frequenza / basso rumore.
I valori di:
- IDSS = 1–20 mA
- gfs = 5,5–7,0 mS
- rDS(on) = 100–500 Ω
- VGS(off) tipico = −3,5 V
che compaiono in alcune tabelle sono riferiti al
PROCESS 50 / caratteristiche generali del processo
National Semiconductor e NON devono essere considerati
come i limiti specifici del 2N4416A.
DATI ELETTRICI
Min: 5 mA
Max: 15 mA
Tipico: circa 10 mA
Min: 4,5 mS
Max: 7,5 mS
3. VGS(off)
Min: −2,5 V
Max: −6 V
4. rDS(on)
Max: 150 Ω
5. Ciss
Max: 4 pF
6. Crss
Max: 0,8 pF
Max: 4 dB
f = 400 MHz
RG = 1 kΩ
f = 400 MHz
VDS = 15 V
ID = 5 mA
Min: 10 dB
9. VDS / V(BR)DSS
35 V
10. V(BR)GSS
35 V
Max: 100 pA
12. Package
TO-72
NOTA
I valori di:
- IDSS = 1–20 mA
- gfs = 5,5–7,0 mS
Per il 2N4416A è quindi preferibile usare:
IDSS 5–15 mA
gfs 4,5–7,5 mS
VGS(off) −2,5…−6 V
rDS(on) ≤150 Ω
Ciss ≤4 pF
Crss ≤0,8 pF
NF ≤4 dB @ 400 MHz
Gps ≥10 dB @ 400 MHz
